    Any ideas for a solution?
    8 Posts 5 Posters 1.3k Views 5 Watching
    • P Offline
      peweuk
      Attached below are two images of a component.
      The component is made up of 3 sub-components - a top and 2 sides.
      One of the attributes options is to change the 'inset' which controls the position and size of the top (the sides remaining static).
      Everything in the attached model works except the diagonal cut at the front (see second image) the ends of which need to always be in line with the ends of the sides.
      Does anyone have any ideas about how this could be done, if indeed it is possible in Sketchup?
      inset problem.skp
        remus
        Its a bit long winded, but you could probably do it by making each individual face of the top a component and adjusting it like that.
        • Chris FullmerC Offline
          yeah, changing the shape of geometry is outside the scope of DC's. That is into ruby territory. So you would have to do it by dividing the top board into pieces that can be scaled separately. Think of it like this:
          Then the triangle piece always stays the same but you scale the 2 rectangles as needed. You would also hide the lines you dont want showing. Hope that helps,
          Chris
          All my Plugins I've written
            BUDLA
            Look this maybe useful:Nriiul Dia kahe riiuliga.skp
            Budla.
            • P Offline
              peweuk
              Thanks Guys.
              I had another configuration that needed a solution and started to consider breaking that up into sections.
              Before I had time to address it your replies came in thick and fast and now I can see a way of doing them both.
              I just have to figure out the maths to make sure they work parametrically as they should.
              Thanks again.
              • P Offline
                peweuk
                OK, all my models have been adapted and work perfectly for sizing etc.
                But I now have a question about textures.
                The image below shows a typical configuration of 3 separate components.
                All have the same texture applied, but the texture shows differently on the three parts.
                I realise that the tiling in the grain direction could be an issue as the components have different lengths and the triangular piece is not a multiple of the texture image size, but I don't understand how the grain width is being shown extended differently on all three parts as if the texture image is being stretched instead of tiling.
                Any suggestions?
                  BUDLA
                  Any suggestions?
                  [attachment=0:df9100ga]<!-- ia0 -->problem texture - tiling.jpg<!-- ia0 -->[/attachment:df9100ga]
                  Yes it is problem for me too?
                  Maybe Ruby guys help us?
                  • scottliningerS Offline
                    scottlininger
                    Unfortunately, there's not an easy way to do what you're talking about. As you scale things like this your textures will start to line up poorly. One could imagine a ruby script that fixes this, but it wouldn't be particularly easy.
                    Better texture support is a common feature request for DCs, so it's good to see a concrete example of why it's needed. Wish I had a better answer for you.
                    Cheers,
                    • Scott Lininger
                      SketchUp Software Engineer
                      Have you visited the Ruby API Docs?
