    Scrambler.exe
    8 Posts 6 Posters 1.7k Views 6 Watching
      toxicvoxel
      Is there any documentation available for using scrambler.exe?
      As allways help is very much appreciated.
        azuby
        Scrambler.exe yourfile.rb
        Well - should be a really short documentation 🤣
        azuby
          RickW
          That's awfully complicated - I just drag the .rb file icon onto the scrambler.exe file icon. 😄
          RickW
          www.smustard.com
            azuby
            😮 You do D'n'D? I thought, you're a real cool programmer 😄 using vi and so on.
            azuby
              Jim
              You can also put a shortcut to scrambler in your right-click Send To folder. Works with more than one selected file, as does dragging and dropping.
              • F Offline
                fizgig
                I'm using scrambler.exe for the first time. I get an .rbs file out of it. I then try to load the file using a loader script in the plugins folder:
                Sketchup.load('path to file/file')
                It doesn't seem to load because when it loads unscrambled, I can see the new buttons that the script creates. When I load the encrypted file, I don't see them so I guess it isn't loading.
                I then add a line to the loader to show the ruby window before trying to load my scrambled script and the window shows up but no Ruby errors are shown in it.
                I don't see a heck of a lot of documentation on this, does anyone know what I'm doing wrong?
                • F Offline
                  fizgig
                  I just realized that it is loading as I can click on the blank spot where the icon should be and the program runs. I just need to get the graphic into that button.
                    tomasz
                    SU unscrambles the file in a temp or virtual folder, so if you point your icons relatively to the script file, it simply doesn't find them. The problem is caused by a wrong path to the icons.
