    Where can I find the material model vray in 3ds
    11 Posts 7 Posters 2.1k Views 7 Watching
    • F
      fymoro
      Hi all,
      Maybe some one have this model in 3ds or sketchup ?
      I want to make my own material library for Vray.
      Thanks & Happy new Year.
      http://www.thearender.com/cms/index.php/news/featured-artists/137-frederic-yves-moro.html
      • F
        fymoro
        This model or something similar, Thanks
        • J
          juanjo06
          go for the web:
          http://www.vraymaterials.de
          just for 3ds max material.
          not for .vismats vray for su material 👍
          • M
            moghamdi
            fymoro,
            check this site it has Vray materials for Rhinoceros 4 that can be used with Sketchu:
            http://www.3dtraining.ch/index.php?option=com_remository&Itemid=176&func=select&id=5
            • F
              fymoro
              Thanks you two,
              moghamdi, thanks for the site in French ☀
              • S
                ScottPara
                Why not use the material editor for Vray. It is a standalone app that makes and previews materials for Vray.
                Scott
                Love the fact that some HATE my avatar.....
                • M
                  materialdb
                  we've actually have one done for http://www.material-db.com (Vray for Sketchup 6) ... feel free to use it!.. and maybe upload some new materials 😉
                  http://www.material-db.com/images/tescene-banner.jpg
                  free vismat materials: http://www.material-db.com
                  • FrederikF
                    Frederik
                    Interesting "Material model"... Thanks for sharing... 😉
                    But are you aware that it's way out of scale..??
                    Although the grid shows that it should be 2 cm per small square, it's far from... 😕
                    ❗ Please remember that ALL Global Illumination render applications are using physical laws and "real world" parameters... ❗
                    One of the most important parameters is to ensure that your scene/model has the correct scale... 😉
                    http://www.kerkythea.net/users/Frederik/Kerkythea-test.jpg
                    Cheers
                    Kim Frederik
                    • H
                      huyvuvn
                      http://www.mediafire.com/?oyx1ghjdmos
                      this is model to test rendering material ^^
                      cheersss
                      happiness on the way, not in the destination.
                      • F
                        fymoro
                        Thanks Vu, Saigon Solidarity 😄
                        • M
                          materialdb
                          hi frederik
                          the 2cm grid might not be in proper scale but the rest of the model is... the ball inside is roughly 4cm in diameter and the outer ball is 6 .. as far as i can remember...
                          Try fitting a squaremeter tiles on it an you pretty much get stuck.
                          It's up to the user how he scales the texture on it -in realscale you won't see much of a floor. On the other hand this would suit more detailed textures...
