    Intersecting planes
    3 Posts 2 Posters 439 Views 2 Watching
      Stewy
      Hi everyone, firstly happy New Year to one and all,
      I have a curved roof dormer window intersecting with a pitched roof slope (a single, angled plane) and have used the push/pull tool to drag the cruved roof through the plane of the pitched roof and it looks fine except that I'd like a nice crisp line to define the intersection of the two. I tried using the arc tool but this wouldn't work because the intersection isn't actually an arc.
      Is there a tool that I can use to define the intersection and erase the bit of the curved roof on the inside of the pitched roof that I don't need?
      Thanks,
      Stew
        Hi Stew,
        Select both faces (they need to be in the same editing context - i.e. not in separate groups for instance) then right click and from the popping up context menu select "Intersect" > "...selected".
        Now this will make that nice intersection line you want to create but you will need to remove unwanted geometry manually.
          Stewy
          Thank you Gaieus, that worked a treat, a happy New Year to you and your family,
          Stew
