    Importing Image
    4 Posts 3 Posters 560 Views 3 Watching
      jahogs
      I am trying to import a image with no background in it. I have a image of a Arkansas Razorback and am trying to insert the image on a football field with no background around it. When I insert the image it has a white background but I am only wanting the cut out of the Razorback inserted. I have photoshop elements and I am cutting out the image with no background. But when I go to save the file it keeps the background.
      Here are some image of what I am trying to do.
      http://i191.photobucket.com/albums/z57/jahogs/Arkansascopy.jpg
      This is the image that I want to put at midfield but with no background just simply the razorback.
      Here is the stadium
      http://i191.photobucket.com/albums/z57/jahogs/Image6.jpg
      • honoluludesktopH Offline
        honoluludesktop
        Go here for help.
        http://www.sketchucation.com/forums/scf/viewtopic.php?f=22&t=6687
          Hi Jahogs,
          JPG image format does not support transparency (i.e. ant part such as a "background"). Among the file formats SU can import, both TIFF and PNG can have transparent background but even if you go transparent with them, they will have a rectangular shape which you could see through (and not the grass).
          So your best thing to do would be to trace around the boar/hog whatever it is in SU and delete the outside edges of the rectangular image. Something like this.
          ArkansawBoar.skp
          Or what HDT posted above. πŸ‘
            jahogs
            Thank you very much. I have spent hours trying to figure it out and it was right under my nose. Thanks a lot.
