    Resizing
    4 Posts 3 Posters 579 Views 3 Watching
    • DamaTheCatD
      DamaTheCat
      Hello & Happy Holidays.....
      I have designed an Armoire, but now find that I would like to change the height and width only. I have studied the "using tape tool" tutorial and can use it, but is adjusts everything. I also know how to change components using the select/move tools, which would take forever to do the drawing. I just need to do a change to the entire model, but only height and width.
      "RdEdits" has a great looking add on, but it is only for Windows........... Us Mac users always have to beg.....
      Any help is appreciated.
      Mike
      Every Day I Try To Be The Person My Dog Thinks I am.......
      • GaieusG
        Hi Mike,
        How about the Scale tool ?
        Use the top middle grip too scale only the height and again, the middle grip to scale on the side.
        • pbacotP
          Hi Mike,
          I feel compelled to pass this along- you CAN use the tape measure to get exact width or height etc. if you do it inside a group of the armoire. Then it will only affect what's in the group. I just learned this finally in the following video. http://www.sketchucation.com/forums/scf/viewtopic.php?f=18&t=15162&st=0&sk=t&sd=a&start=30#p116666
          Peter
          • DamaTheCatD
            DamaTheCat
            Gaieus, pbacot,
            You guys are great! Hope your holiday is going good and lots of stuff to play with.
            Gotta confess, after I posted my question it dawned on me about the "scale" tool. And I figured out about the different ways to use it..... good stuff. Feel bad about asking, but at the time I was lost.
            Only drawback is if I resize the "thing" none of my "scenes" of the "thing" change to the new size..... It's not a problem because making several new dimension scenes is easier than resizing each component or a complete re-draw. I'm back cranking down the road..........
            pbacot,,,,,, I like the "tape" tool and will play with the site you sent.
            Thank again to both of you,,
            Later
            Mike
