    Get the old sketchup 6 back
    9 Posts 8 Posters 2.4k Views 8 Watching
      Matt5674
      I got sp7 and sketchyphysics only works for 6!!! 😞 😞 😞 😒 is there a way I can uninstall sketchup 7 and get sketchup 6 back?
      • Chris FullmerC Offline
        SU6 should still be there unless you uninstalled - which was not necessary. If you did uninstall it, then hmmmm, i tihnk someone around here should have a link back to a v.6 download - maybe.
        Chris
        All my Plugins I've written
          Maybe here?
          http://sketchup.google.com/gsu6/download.html
          Just a quick Google search: "google sketchup 6 download" > second result πŸ˜‰
            BTM
            ...and if you install it correctly, sketchyphysics SHOULD run in SU7.
              Jackson
              SketchyPhysics runs fine in SU7, I just copied and pasted all the SP files from my SU6 folder to the SU7 folder and have had no problems running it. Did you remember to copy the SketchyPhysics folder as well as the .rb?
              Jackson
              • P Offline
                Platypus5
                It is hard to get it to work with SP7, but it is still possible actually. Copy the Plugins folder in the SU6 and replace the one in SU7 with it. Idk, but I think thats what I did. I forget. Regardless, it wont matter, as you can download models from the warehouse as su6, even if they were uploaded as Su7.
                  Matt5674
                  I copied it and it worked!!! thanks for the tip
                    darkPhysics
                    Here is my video about getting SP2 in SU7. Link: http://www.youtube.com/watch?v=Buv-MLhIJrk
                    • V Offline
                      Verrou
                      Way to go, bump a thread that's over 2 months old -.-
