    How to modify Default Layer Geometry Ruby
    4 Posts 2 Posters 1.1k Views 2 Watching
    • S
      sorgesu
      I wanted to have an alternative version of this ruby script that defaults everything to a layer1 which I created.
      I altered the script so all references ( and the ruby file name) are changed to "layer1" instead of "layer" but I cannot actually figure out how to set the appropriate variable to actually do that.
      I am not a ruby programmer so I don't know anything.
      It looks to me that this bit :"layer=nil" is just keeping the layer that components and groups are associated with stay the same as is.
      So, what do I change please. Many thanks.
      This is TIG's script below with my changes:
      =begin
      Copyright 2008, TIG (c)
      Permission to use, copy, modify, and distribute this software for any
      purpose, and currently without fee, is hereby granted, provided that
      this text and the above copyright (c) notice appear in all copies.
      This software is provided "as is" and without any express or implied
      warranties, including, without limitation, the implied warranties of
      merchantability and fitness for a particular purpose.
      Description: Defaults all layers for all selected geometry to layer1 ( susan sorger December 2008).
      Groups and Instances are not changed
      BUT their contents are zeroed
      Author: TIG
      Usage: 1. Select one of more entities.
      2. Activate the script from the Plugins Menu
      History: 1.0 20080310 First issue.
      =end
      require 'sketchup.rb'
      class DefaultLayer1Geometry
      def to_default(entity)
      entity.definition.entities.each{|e|to_default(e)}if entity.typename=="ComponentInstance"
      entity.entities.each{|e|to_default(e)}if entity.typename=="Group"
      entity.layer=nil if entity.typename!="ComponentInstance" and entity.typename!="Group"
      ### only processes non-group or compo-def layers
      end#def to_default
      def process()
      Sketchup.active_model.selection.each{|e|to_default(e)}
      end#def process
      end#class
      def default_layer1_geometry
      if not Sketchup.active_model.selection[0]
      UI.messagebox("Default Layer1 Geometry:\nSelect Objects BEFORE Running.")
      return nil
      end#if
      Sketchup.active_model.start_operation("Default Layer1 Geometry")
      DefaultLayer1Geometry.new.process
      Sketchup.active_model.commit_operation
      end#def
      is_this_file=File.basename(FILE)
      if not file_loaded?(is_this_file)
      UI.menu("Plugins").add_item("Default Layer1 Geometry") {default_layer1_geometry}
      end#if
      file_loaded(is_this_file)
      Susan Sorger
      • S
        sorgesu
        Oh that's amazing. Thanks so so much!
        Susan Sorger
        • TIGT
          See:
          entity.layer=nil
          Because 'nil' == "layer0" (or whatever the default layer might be called in another language)
          To set things to "layer1" you use...
          entity.layer="layer1"
          This assumes that 'layer1' already exists... if you want to make sure that it does first then add this line early on in the script...
          Sketchup.active_model.layers.add("layer1")
          • TIGT
            ¡ No problema !
            Ask and ye shalt receive...
            Seasons greetings...
