    Sphere Manipulation
    4 Posts 4 Posters 825 Views 4 Watching
    • F
      Fatolbaldguy
      OK I can make spheres and complex rounded objects. Yes he can be taught! Now I need to know how to cut grooves and window holes into these curved and round surfaces. I really do look for the tutes for this stuff before I ask here but I have yet to find one on this subject. Thanks in advance.
      Due to financial constraints the light at the end of the tunnel will be extinguished until further notice.
      • R
        remus
        Probably the most versatile way to do things like this is with intersections.
        In essence, you get the 2 bits of geometry you want to intersect->select them->right click->intersect->with selected.
        If you have a play around with this im sure you'll get the idea in no time πŸ‘
        • GaieusG
          There is a nicely performed tutorial about it here:
          http://www.sketchucation.com/forums/scf/viewtopic.php?f=18&t=11222
          • H
            Hazza
            I have attached a 2 scene model, the first has a complete sphere with 2 other objects poking into it.
            The second is the result of:
            1. Double clicking the sphere to edit it
            2. Going "Edit -> Intersect -> Intersect with model"
            3. Deleting the 2 boxes
            4. Deleteing the faces no longer needed
            5. Adding the lines that completed the internal faces
            sphere-tut.skp
            See all of my SketchUp models here.
