    CAD v Modeling
    45 Posts 23 Posters 7.4k Views 23 Watching
    • honoluludesktopH Offline
      honoluludesktop
      TommyK, no argument from me. Where 3D proves to be an efficient way to communicate, I have no doubt that it will be quickly assimilated into the overall process. Within the constraints of my system, your plan to draw every stud is ambitious and admirable.
      A light note about progress: In my mid 20s I once drafted on my own time, first in pencil, then traced over freehand in ink, a residential 3 sheet set of plans. My boss thought I was nuts. At that time, residential contractors were working craftsmen, capable of building by themselves, everything wood in the dwelling from framing to cabinets, and doors. In the beginning of my practice, I was lucky to build two houses with fellows like this before their kind retired from the industry. Between the Architect, and these craftsmen existed the knowledge of what was expected. One of the old timers in the days of my youth told me that when he started, his library of manufactured products fit in a paper box, a file folder in height and width by 24 inches deep.
      • P Offline
        precisedix
        Yeah, also think builders appreciate 3D information, since it is so easy to read. I think 3D information is far better at communicating an overview of the phases of project....
        aluminum plate
        • pbacotP Offline
          3d information. I don't think so. Not for building. Very good for complex connections but even those would probably require an interactive model or multiple views, where an orthographic view is easy for a builder to navigate.
          I like to include isometric cutaways for some standard waterproofing details, but I wouldn't want to draw all custom details like that. Sometimes it's good for the concept. I showed a steel connection to an engineer with a SU image, and he "got it" right off, whereas he wasn't quite reading it from our plans before that. But he then made orthographic construction drawings for the builder.
          On the other hand, I met a builder who draws his own 3d detailed framing models before building. Interesting.
          Now if you're talking at the level of Gehry. You CAN"T build it without a 3d model and a computer. That's fascinating, where they build physical models and then digitize them.
            MtnArch
            @dcauldwell said:
            Linea
            I had a look at sti spirit, and it looks interesting. Can't seem to find out a cost for it though - I suspect it is expensive, as things usually are when they won't tell you how much it costs!
            David
            Take a look here : http://www.procadsys.co.nz/
            The dealer, Matt Cockroft, is very knowledgeable and has created a lot of tutorials on Spirit, and should be able to give you pricing. Last I heard it ain't cheap (compared to SU Pro), but it's also a lot less expensive than - say - ArchiCad.
            Alan
            Highest Regards,
            Alan T. Hendry, RA
            Architect
            • broomstickB Offline
              broomstick
              @dcauldwell said:
              I am currently trying to develop a workflow link from SU to CAD drawings for architectural work (small scale stuff - houses).
              So far I have worked out that the plans and sections can be exported from SU with a thickness applied to the section cut, thus eliminating the need for linetype adjustment later. I am currently using CAD to add dims and some shading to the SU import. That just leaves the actual detailed drawings and as I import these as 'standard' details (to be adjusted per project) this is quite simple.
              With discipline in the creation of SU model, so far this is working quite well.
              David
              Your response got me thinking, because one of the major issues of exporting a section cut aligned view from Sketchup are alle the single lines you end up with in the drafting program. Then I thought about Archicad and I think there is a nearly automatic solution for this problem:
              Since version 11 Archicad has intoduced a feature called "linework consolidation", that lets you transform all the 2d lines you get from a cad in single polilines. It allows you to transfer all of these lines on a single layer of your choice, change the colour of those lines and so on. This comes from the need to create more polished drafting from an autocad import, but now it occurred to me it would work nicely with a dwg file coming from SU as well. Will havo to try it out!
              • 3 / 3
