    How do you add hotkeys to context menu commands?
    6 Posts 4 Posters 775 Views 4 Watching
      I've got a ruby where all the commands appear only in the context menu. The problem is that I can't assign shortcut keys to these commands in SU. I seem to only be able to add shortcuts to commands located from the menu bar.
      What can I do to be able to assign shortcuts to these commands?
      • V Offline
        Voder Vocoder
        Which context-menu commands are you talking about?
        ~Voder
          Context menu commands I'm adding myself via scripting.
            Jim
            I think context menu commands can have a shortcuts, but the commands will not appear in Preferences/Shortcuts unless they are available in the context at that moment.
            As an example, Reverse Faces does not appear in Preferences/Shortcuts unless at least one face is selected.
              I'll be ... I swear I tried this. But apparently not. When I tried it again now it worked.
              Thanks!
              • bagateloB Offline
                bagatelo
                http://i35.tinypic.com/210y7vd.jpg
