    RpTreeMaker - new version Dec 12, 2008
    extensions
    67 Posts 15 Posters 11.6k Views 15 Watching
    • JClementsJ Offline
      JClements
      Al,
      Seems pretty easy to use.
      1- Anyway to add an option to "smooth" the junctions for root-to-trunk and trunk-to-branch?
      2- Is there a way to stagger (vertically) the primary splitting of the trunk?
      This free version for SU would make a good standalone product ... but with a small price of course. 😄
      • Al HartA Offline
        Al Hart
        Since SketcnhUp is free, it is probably not much effort for someone who wants a stand alone, to just use SketchUp.
        Would you like some other options - such as save image and launch into a paint program?
        Or if you are interested in a stand-alone, we could discuss features to add and let you consider marketing and supporting it. We are planning to add shrubs, bushes and other things in the next version.
        In a for money version, we could also export a 3D file for use in SketchUp or other CAD systems.
        Al Hart
        IRender nXt from Render Plus
          JClements
          Hi Al:
          From my perspective, as an illustrator, where I have to take photos of sites and modify/enhance them by adding foliage, your app would be very helpful. I know when the situtation arises, I will open SU, create a tree or whatever, and save out the transparent PNG and then import that image into a pixel program or a vector program like CorelDRAW or XaraXtreme to do my final layouts.
          In situations where I am not concerned with creating 3D geometry I would just as soon open TreeMaker directly. I did try that already by firing up TreeEditor.exe, which worked fine and I could save an .ArPlant "template" file. However, I didn't see a way of opening the RpTreeMaker dialog without using SU (if there is a way to do this then my posting has been answered 😉 ). Otherwise, I could see where TreeMaker Basic standalone (a non-Pro version) was avialable to create transparent PNGs, GIFs, or TIFs and priced at a reasonable price (say under $30 ????) then it might serve as a nice niche application. Additionally, it could have: 1) a link to your site to browse, purchase, and download a tree or libraries of trees in .ArPlant format; similar to the way FormFonts offers its product, and 2) an option to import an image as a background (similar to SU's watermark feature) to facilitate creating trees/foliage with the right proportions.
          I haven't any market research to support this suggestion and I don't know what your development costs have been so it may not be economically feasible, but I got the impression you've already addressed all the ground work programatically to do this.
          Regards,
          John
          • Al HartA Offline
            Al Hart
            Thanks for the input. I will consider such a product.
            For you own (and other readers who want to run this outside of SketchUp) use, use the Batch Mode in RpTreeMaker to create a batch file.
            http://www.renderplus.com/pdf/RpTreeMaker_w.htm#Batch_mode
            http://wiki.renderplus.com/images/3/3c/RpTreeMaker-Batch.jpg
            Follow the logic to run the batch file manually. As part of this you will get a .bat file which runs the tree-editor and then runs the image maker. With a little modification (You can change the .bat file to use %1 as an argument for the final image), you can use this to create trees from outside of SketchUp.
            As a plug for our other products, (people who hate commercial plugs in posts skip this next part), try using IRender nXt to make even better renderings of your trees for use in other applications. IRender nXt lets you save the entire rendering as an alpha-transparent image for pasting in other images.
            http://wiki.renderplus.com/images/f/fb/Tree-w-IRender.jpg
            Al Hart
              JClements
              Hi Al:
              I followed your instructions (sort of).
              After the batch file was created, I copied it and renamed as RpTreeMaker_Standalone.BAT and then made a shortcut to it and dropped the shortcut into my Programs folder.
              That seems to work pretty good. However, the resulting PNG file is buried deep in my Document and Settings folder and always given a name of "Standard Tree (9).png (I'm guessing that was the original "template" tree name).
              I am pretty shakey with my DOS commands (only been 10 years since I've last typed one in from memory at the Command prompt or created a batch file 😲 ).
              Is there way that you could modify the attached batch file to:
              1- direct the PNG file to my C:\Programs\RpTreeMaker\My_Tree_Library folder and
              2- give the PNG file the same name as the .ArPLant file it came from?
              John
              RpTreeMaker_Standalone.BAT.TXT
              • Al HartA Offline
                Al Hart
                I think the trick is going to be to modify the RpTreeMakerArgs.txt file:
                Mine looks like this:
                C;\tmp\RpTreeMaker>cat  RpTreeMakerArgs.txt
                *@KEY;CALLING_APP;RpTreeMaker
                *@KEY;APPLICATION_FOLDER;c;/devc_2005/IRenderBatch
                *@KEY;PLANT_FILE;c;\tmp\RpTreeMaker\RpArPlant.ArPlant
                *@KEY;SIZE_FILE;c;\tmp\RpTreeMaker\RpTreeMakerParams.txt
                *@KEY;PLANT_PASSES;1
                I think that if you change the IMAGE_FILE entry, it will store the image in a different place.
                Al Hart
                • Al HartA Offline
                  Al Hart
                  Some people have been having problems running the Tree Editor, either from SketchUp, or directly from the disk.
                  We now have it creating a debug file as it loads. If you have been having this problem:
                  1. Download the latest version from: Downloads
                  2. Start the Tree Editor.
                  3. If the tree editor fails, go to the RpTreeMaker menu under windows and select Show debug file. Send us the content of the debug file so we can determine where it failed.
                  Al Hart
                  • 4 / 4
