    Components and Groups Don't Always Make
    6 Posts 3 Posters 1.4k Views 3 Watching
    • J
      Jim57
      I have intermittent problems with both components and groups. The problems are similar and may or not be related. Since they are two ways of grouping I will describe them together.
      Groups— sometimes when I make a group, then come back and click on one element in that group, it highlights. It seems to me that the group has not formed. So I select everything again and go to the menu, and "Make Group" is still dark. I do it again, and again, until I lose patience. The group never forms.
      Other times I can make a group no problem, and when I click on it the whole thing selects.
      Components— Sometimes when I select objects, then click "Make Component," the same thing happens. I can click on one element separately. I'm attaching a file where this occurred. Note that the Components Manager shows the component, and I can add more components, but that the one I added, the rectangular slab, does not select as a component.
      Other times I can make a component, click on it and the whole thing selects.
      I'm not in edit group/component mode here, it's normal times. I had this problem with Groups in SU 6 as well.
      I'm using Freebie 7 on a MacBook Pro with a Nvidia GeForce 8600M GT graphics card and 2 G of memory, running System 10.5.5
      Thanks for any suggestions,
      Jim
      Presiders Chair.skp
      • R
        remus
        When your making groups/components make sure you select some edges to group as well. Ive found SU to be a bit picky about grouping things that dont have any edges selected.
        • J
          Jim57
          In the example I attached, the only edges I did NOT select were around the bottom of the rectangular solid. After I posted, I went back and tried selecting them also, and it did not matter, same reaction.
          Best,
          Jim
          • R
            remus
            Thats pretty weird, im not having any problems grouping anything.
            • GaieusG
              Hi Jim,
              Maybe I am wrong but make sure that when creating the component, at the bottom lesft, "Replace selection with component" is checked.
              There are two basic scenarios:
              when a set of selection shares some geometry that will be outside of the component being created (like in your case - the bottom lines also define faces outside the to-be component), this checkbox is not checked by default.
              When your selection doesn't touch any other geometry, the box is checkedby default.
              Often one makes this little mistake when in a rush (including me). There have been "feature requests" to enable that checkbox by default in the first scenario as well.
              • J
                Jim57
                Thanks, Gaius, that's exactly what I was doing.
                I'm guessing the grouping thing is some sort of funk on my computer, if others can't duplicate it with this file.
                Best,
                Jim
