    .erase! bug ? or is it me...
    4 Posts 3 Posters 615 Views 3 Watching
    • Didier BurD Offline
      Didier Bur
      I'm getting bug splat doing that:
      def my_function
         Sketchup.active_model.start_operation
         p1=Geom;;Point3d.new(0,0,0)
         p1=Geom;;Point3d.new(100,100,100)
         e=Sketchup.active_model.entities.add_line(p1,p2)
         g=Sketchup.active_model.entities.add_group(e)
         g.erase! if g.valid? #ALWAYS CAUSES A BUG SPLAT
         Sketchup.active_model.commit_operation
      When NO start/commit instructions are done, no bug splat. 😲
      Workaround:
      def my_function
         UI.start_timer(0,false) { g.erase! if g.valid? }
      No more bug splat but the start_timer seems to do itself a 'commit' so the function is no more one-click undo-able.
      Anyone has a better solution to avoid bug splats within star/commit ?
      Help greatly appreciated !!!
      DB
      • W Offline
        Whaat
        have you tried using:
        Sketchup.active_model.entities.erase_entities(array_of_entities)
        I think I have got bug splats from using erase! before but when I tried the using the above code, it worked fine.
          I'm having the same problem with SU bugsplatting when trying to delete a valid entity. Doesn't matter what delete operation I do. I keep bugsplatting.
          If I remove the start_operation line it doesn't bugsplat while running. But seem to terminate early. And when I afterwards do a Revert or try to make a new model SU will bugsplat.
            Didier Bur
            Thanks Whaat, it seems to works here too, even with a single element array.
            Fingers crossed !
            DB
