    Sketchup 7 Controll panel problems
    12 Posts 5 Posters 2.0k Views 5 Watching
      cam72cam
      I downloaded SU7 and installed sketchyphysics. I pressed play after I loaded a new model. The control panel didn't show up. Then I opened inspector.html in notepad and made a link to the control panel. it made it to the page, but no sliders. This is a big problem. help. I am an experienced sketchyphysics and sketchup user.
      http://robot.meshfamily.com/sk1.png
      inspector : I clicked on the link I made 'control'
      http://robot.meshfamily.com/sk2.png
      control panel
        cam72cam
        I am using 2.1 beta
        • F Offline
          fredfy
          same problem here, control panel doesent come up when i start simulation. also i
          cant find the UI to conigure controller etc
          Fredrik
            cam72cam
            I am just going back to sketchup 6 until the problem is resolved
              BTM
              are you sure that it's installed correctly?
                cam72cam
                Yes I am positive, I am no newbie to sketchup and sketchyphisics. I have only modified the UI to create a shortcut to the control panel because it did not show up. It didn't work before either.
                • F Offline
                  fredfy
                  Problem solved..
                  I had to reinstall windows
                    cam72cam
                    What?? Why reinstall windows?
                    • F Offline
                      fredfy
                      I had no other ideas of what to do.. it neither worked on su6 or 7 and i had work to do..
                      Fredrik
                      • soloS Offline
                        solo
                        Yikes!!
                        That's an extreme solution, I am sure there must be another work around.
                        http://www.solos-art.com
                          cam72cam
                          I have looked in the registry and have found differences between the sketchyphysics in SU6 and SU7.
                          I don't know why.
                          maybe, just maybe, the sketchyphysics installer installed the registry keys into SU6 and not SU7
                            darkPhysics
                            Look at my video about making SP2 work in SU7. Link: http://www.youtube.com/watch?v=Buv-MLhIJrk
