    SU to vue, bad moire in renders
    extensions
    6 Posts 5 Posters 1.1k Views 5 Watching
      mirjman
      not sure if this is a vue setting or an image map translation problem, but I am getting some extreme moire when exporting images of SU models in vue - check out the waves in the far side elevation and sunflower patterns in the end elevation. Any pointers?
        remus
        Try and use large high quality textures, and also render your images out very large (and resize them if needed.) This should help alleviate the problem.
        • soloS Offline
          solo
          Mirjman
          I actually find Vue pretty good as far as the moire effect goes, I never get such results. Could you send me the .vue or .vob and I will see if I get the same results, if I do not I will return it with my setting attached to it.
          Pete
          http://www.solos-art.com
            rcossoli
            Hi Solo, I recently started to see that the Vue and I also feel that these very advanced in use now. would be a lot of trouble if left some screen shots for those who recently started where they can see that there are configurations that take into account and that values, especially in the Options menu and rendering.
            and even better if the version 6
            thank you very much.
            THREEDIMENSIONSWEB dot COM
            • H Offline
              holgster
              maybe some higher anti-aliasing settings could solve the problem
              Choose user settings in the render-presets.
                mirjman
                holgster- that seems to fix the problem. "texture anti-aliasing" was unchecked for the "final" settings
                thanks!
