    My working methods - WIP with pics.
    27 Posts 14 Posters 3.7k Views 14 Watching
    • A
      andyc
      I've had several requests to explain my work process. So, here's an ongoing project, step-by-step. Not completed yet, but I'll post the final version when it's done.
      Step one: the SketchUp model. I've always described my models as 'basic' - and you can see here that I wasn't joking!step1.jpg
      Step two: photo reference from the web...step1b.jpg
      Step three: the photos were cropped, manipulated and re-touched to produce about seven or eight texture maps, which were applied to the SU model...step2.jpg
      • M
        mateo soletic
        Andy,
        Great images and thanks for sharing your interesting work flow.
        Concept Illustrations
        • A
          andyc
          Step Four: Into 3DSMax - here the model was lit from a single source, sky and atmosphere was added, and the water surface was added. This was exported as a jpeg at 4096 pixels wide...step3.jpg
          Step Five: Photoshop time!! Lots and lots of hand painting to add detail and individualise the structures. Plus add additional lighting, colour-correction etc. At this point the Photoshop work is approx 20% done.step4.jpg
          And here is an enlarged detail showing before and after the Photoshop work...step5.jpg
          That's it for now. As the Photoshop work progresses, I'll post more updates. Hope this is of some interest or use to some of you.
          Andy.
            Is the final result is a 2D illustration or a 3D file?
            • A
              andyc
              Final result is a 2D illustration. (However this could then be projected back onto the geometry using camera mapping in 3DSMax to give a semi-3D result.)
              A.
              • soloS
                solo
                Thanks for the insight into your workflow, very interesting. I've always wondered how you achieved your amazing futuristic/post apocolyptic images. I am interested in your Photoshop techniques and tools, do you use a tablet for painting?
                http://www.solos-art.com
                • A
                  andyc
                  Thanks Solo.
                  Yes, use a Wacom Bamboo tablet.
                  For simpler compositions I often skip the 3DSMax step, and do all the lighting and environment stuff direct in Photoshop. However for a big scene like this that would be a bit labour-intensive!
                  Photoshop wise, it's a pretty basic arrangement: The rendered image; a layer for hand-painting; a layer for lighting/atmospheric effects; an adjustment layer for colour curves; and adjustment layer for brightness/contrast; and an adjustment layer for colour balance.
                  Andy
                  • spenceS
                    spence
                    This is really cool stuff Andy. I could use some more info, keep it coming.
                    Spence
                    • marked001M
                      marked001
                      thanks andy....have been waiting for this.. i might have to ask for a tablet for xmas... i say that every year i think 😄
                      http://www.revision21vis.com
                      instagram: revi21on
                      • A
                        andyc
                        Time for another one. Same SU model, re-rendered and re-painted....
                        A.
                        • soloS
                          solo
                          That's awesome, please post an image or explain what is 3d model, photo, mix, etc.
                          I was staring at image trying to dissect it and understand your process.
                          • A
                            andyc
                            Hi Solo,
                            Ok - hopefully this helps :
                            The plane wreck took quite a bit of work: the reference photo was taken on a grey, cludy day, so all the light and shade had to be hand-painted in Photoshop.
                            The composition isn't quite there yet, but some human figures will be added in on the left, which I'm hoping will balance things up.
                            A.
                            • soloS
                              solo
                              Thanks for the clarity, I need to get my editing skills up, work like this inspires me to get my ass in gear and start learning. unfortunatly I'm trained (sort of) in Paintshop pro (long story that began with Corel draw) and kinda on the fence about changing to Photoshop.
                              thanks again.
                              • A
                                andyc
                                Hi Solo,
                                For this level of work Paintshop Pro would probably be fine. I haven't used it for a while, but the later versions seemed to have really improved the painting tools. That said, I've found Photoshop's colour-correction tools to be a big step ahead - which is really useful for integrating different images together.
                                A.
                                • D
                                  DzineTech
                                  Amazing work as always Andy 👍
                                  • E
                                    ELYSIUM
                                    Great Post, its good to finally understand how its done!! keep those pictures coming.
                                    Lots of ilustrators are using sketchup as their main modeling tool for its speed, improving their work later on photoshop, check ou this work:
                                    http://ryandemita.blogspot.com/2008/11/crossing-bering-strahttpwwwbloggercomim.html
                                    • A
                                      andyc
                                      Thanks for that link - that guy has some nice work!!
                                      Yes, for me SU is really a layout and perspective tool - by speeding up the basic stuff it frees up the time to focus on the creative aspects - which is what any good design tool should do.
                                      A.
                                      • tinanneT
                                        tinanne
                                        Andy, I'm am so happy you started this post. I am a big fan of your work and have always coveted a glimpse into your world. I am way behind on "painting" in PS but I really want to learn. What resource would you suggest for learning these techniques other then practice, practice, practice.....?
                                        Executive Director : American Society of Architectural Illustrators
                                        AIP 30 Competition opens soon. ASAI.org
                                        Architectural Rendering
                                        • A
                                          andeciuala
                                          Hi andy, great work man, i'd like to know how to use photoshop just like you. It's great, i'd like to see the full res image.
                                          • A
                                            andyc
                                            Thanks guys.
                                            Tina: afraid its all the dreaded 'p' word 😉 Besides which, I have the attention-span of a goldfish, so prefer the 'get-stuck-in-and-learn-by-doing' approach 😄
                                            That said, theres a lot to learn (and admire) here http://www.conceptart.org and here http://www.mattepainting.org
                                            A.
                                            • 1 / 2
