    Environmental Modelling
    5 Posts 4 Posters 646 Views 4 Watching
    • M
      mw-fox
      Dear Designers.
      For my MSc I am currently researching into environmental modeling as a tool for very the early design stages of a project. The theory is that there should be a simple tool that can be used to simulate sketch designs - to get the basic principles right before getting planning permission!
      I would appreciate any thoughts on this, and I have also put together a 2min questionnaire, and I would appreciate anyone filling this in for my research:
      http://www.surveymonkey.com/s.aspx?sm=z1mFBI0WgnaHgJDCfMJz5g_3d_3d
      Many thanks, Matt
      • ToboboT
        Tobobo
        Done
        Toby
        Philippians 4:13
        • GaieusG
          Hi Matt,
          I am quite far from any kind of environmental or other design o may just "start" some suggestions here: have a look at the "SketchUp and Green Design" session video (and downloadable PDF's) from BaseCamp 2008.
          Also, I remember that there was a kind of "contest" on such a topic at BaseCamp and quite many members here participated so you might get more proper avice from others.
          • I
            idraft
            Check out here http://www.ecobob.co.nz/ for some New Zealand Eco home ideas.
            Web based tools for energy design - http://www.wbdg.org/tools/tools.php
            BRANZ annual loss factor tool may help you ? downnload the "AFL" tool http://www.branz.co.nz/cms_display.php?sn=17&st=1&pg=1431
            And these links are more likely what your after if SU compatablity is required.
            Energy Rating software
            IES Intergrated Environmental Software
            http://www.iesve.com/content/
            http://www.iesve.com/content/default.asp?page=s156 (SU Plugin)
            YOU can thank me later πŸ‘
            Cheers jeff
            • M
              mw-fox
              Thanks for giving me the links, very useful guys!
              Matt
