    Need help with autocad/illustrator file
    3 Posts 3 Posters 373 Views 3 Watching
    • K Offline
      kouroshrad
      Hi Experts!
      I have traced my plan in illustrator and I imported it into sketchup but I cannot use pull/push. I am in rush and I really need help with it. Is there anyone who can do that for me? I would appreciate that if you give me your email address and i will email the file to you. THANKS!
        Why cannot you use P/P on your model?
        If you have no faces (yet), you will need to cretate them first.
          remus
          You might need to explode the imported linework, as well. just select it->right click->explode.
          You can then run the make faces plugin ( http://www.smustard.com/script/MakeFaces ) to make faces (surprise surprise) that can be push pulled.
