    Request Tutorial how to create Groove Pin
    5 Posts 4 Posters 639 Views 4 Watching
    • N
      neng83
      I'm trying to create groove pin for my project, I don't know how to make the complex shape like these:
      http://www.groov-pin.com/grooved%20pins/gpins_types.htm
      Is there any tutorial that can help me with that?
      Neng83
      • soloS
        solo
        Which type are you after? There are many on that link.
        http://www.solos-art.com
        • V
          Voder Vocoder
          This is actually pretty simple. Here's an example of making two configurations. I didn't bother with any captions on the tutorial because I think it's pretty self-explanatory.
          See what you think
          ~Voder
          groove_pins.skp
          • R
            ridix
            Sorry Voder, can’t open your file. I am still on SU6. I tried to down load SU7 several times without success. I am surprised that Google doesn’t have functioning server???
            Any way here is method two; a pin with larger diameter added where slot is cut. To make the pin and slot cutter I must used Follow me tool. At the end I just smoothed the edges.
            http://www.designonme.com/sketchu/pin.gif
            Of course this level of detail is a over kill if you are just working on assembly.
            • N
              neng83
              Thanks Voder and ridix, that helps a lot, I'll give it a try. I appreciated the reply ☀
