    Another question about Dynamic components and re-sizing
    6 Posts 3 Posters 7.5k Views 3 Watching
    • P
      peweuk
      Is it possible in Sketchup to have individual 'lines' in a component which stay a constant length when the component is re-sized using the scale tool.
      I have attached an example which shows what I am referring to.
      If there is, can anyone explain how? πŸ˜•
      toprail.skp
      • R
        remus
        I think the only way of doing this is by making each line a DC, not very intuitive but i think it can be made to work.
        • J
          Jim
          Break the component into 3 sections - the 2 ends and a middle. Then you can fix the length and position of the ends in relation to the middle, and only allow scaling to change the middle.
          Here's an example.
          toprail.skp
          • P
            peweuk
            Jim.
            Thanks, that's exactly what I need.
            I thought about multiple components, but when I tried it the edges between the three components showed which I did not want.
            How did you hide yours?
            • J
              Jim
              Well, just like you hide any edge. Use the tool with the SHIFT key.
              • P
                peweuk
                Thanks Jim.
                I was not aware of that option (the shift key on the erase tool) - most of my Sketchup experience so far has been for personal stuff and I have so far gotten by with the basics and various tutorials.
                It's only recently with the rlease of V7 and the introduction of Dynamic Components that I have taken a more detailed interest in SU for more serious projects. I see I still have a lot to learn.
                Thanks again.
