    Material: stone + wood supports
    2 Posts 1 Posters 1.5k Views 1 Watching
    • B
      BTM
      I used one of the textures (the one on far left) found at this address: http://www.cgtextures.com/texview.php?id=8474&PHPSESSID=6c1a8d1215b26f52d4722c6c444ed848 to make a great mine/medival texture + bumpmap. I had to do a lot of image editing, mostly using gimp, to get the results I was looking for.
      Here is the texture and bumpmap (bumpmap is also shininess map when inverted):
      NOTE: The texture is tile-able horizontally, and although it is also tile-able vertically, it doesn't match up quite right.
      • B
        BTM
        Here are some images of it being used in kerkythea:
