Hide Blue Axis Only
I like the axes to be visible, but would like to turn off just the Z axis as it's usually in the way. And because the other axes show positive and negative by using solid and dotted lines, you can tell which way Z goes without it actually being visible.
nice idea Jim.
I was also thinking the other day it would be nice also to be able select a function so that faces do not close in. Then if drawing in 2D (eg: construction detailing) may read better and be faster to work with. This coupled with your idea may be a solution to drawing in 2D (with perspective turned off that is).Maybe a 90deg page rotation tool in the 2D direction could work also?
I have to leave the working out of this to someone else ofcourse, but what do you think?
CHeers Jeff
Register LoginAdvertisement
