    Exporting to .dwg
    3 Posts 2 Posters 417 Views 2 Watching
    • P Offline
      peweuk
      I exported a drawing to .dwg format this morning for the first time.
      To test it, I re-imported it to SU and found the sizes were all different by a common factor of x304.8.
      Is there a setting for exporting somewhere that I am missing?
        It's rather at import side - in the import options you have to give the units that you used while exporting.
        • P Offline
          peweuk
          Thanks Gaieus.
          I never noticed the 'options' on the import dialogue box. I was assuming it would import using the default template settings.
          I can send the drawings off now with with no worries.
          Thanks again.
