    Problem with drawing?!
    3 Posts 2 Posters 338 Views 2 Watching
      merlynthekid
      Hi, I'm not newbie, BUT also not professionalist and I'm having the following problem:
      How can I make sings like these http://sketchup.google.com/3dwarehouse/details?mid=8e35eb89d8eb2a37e9d8a35d7a1fb08d&prevstart=0 on the plane? I mean the sign "GOL" on the plane is maked only with some kind of hidden geometry, not with lines on the surface! Till now I have used the Line tool to make these sign, but as I see there is still another way, visible in the hidden geometry mode. And all seems pretier!
      10x a lot for your help.
      G.D.
      • soloS Offline
        solo
        G.D
        If you look closely you will notice he created the text in SU (3d text) then intersected the text with the plane creating the new faces, then deleted the text and painted the faces.
        http://www.solos-art.com
          merlynthekid
          It worked!
          Thank you!
