    Dynamic Components, Interaction and Animation Output
    5 Posts 3 Posters 9.9k Views 3 Watching
    • Tim DanaherT Offline
      Tim Danaher
      DCs can be set to have animated behaviours, but these need to be triggered using the 'Interact' tool, i.e, in real time.
      Does anybody know if these animated behaviours can be built into a rendered-out animation? Doors opening as you walk through them, for instance?
      Ta,
      Cheers,
      Tim
      http://vizarch.blogspot.com
        remus
        Id guess it would be possible, although it would be up to the people who write the exporters to incorporate it.
        Perhaps if their was some way of triggering the animation with a scene, so you click the scene and then the DC does the animation, im just guessing with that one, really.
          Tim Danaher
          No, it can't be done -- it's not supported yet. I have it from the horse's mouth.
          Cheers,
          Tim
            AdamB
            I added support for animation and interaction of Dynamic Components in LightUp. There is a short vid here
            [I don't know what YouTube has done to the quality / framerate of the video, but you get the gist]
            It supports click on DC and also proximity triggering them so you can have doors opening as you walking around.
            I also added some extra optional syntax to the onClick behaviour. You can write:
            animateslow("rotx", 0,45,90),cycle
            And it will animate from 0 to 45 to 90 degrees and back to 0 when you trigger.
            Or you can write:
            animateslow("rotx", 0,45,90),cycle,pause
            and get the same with a pause between each state.
            Or you can write:
            animateslow("z", 0,200,400),forever
            to loop the animation once its triggered.
            Adam
              remus
              Nice one adam, will be interesting to see what sort of animation people can come up with using this.
              p.s. saw that olympic roof you did in lightup tim, very nice πŸ‘
