    Import geodesic coordinates
    2 Posts 2 Posters 1.6k Views 2 Watching
    • J
      jantglez
      I'm starting to get familiar with this tool and I would like to know whether it was possible to insert polygons over a list of geodetic coordinates and then assign them a height in feet?
      how can I do?
      thank you very much
      greetings to all
      • TaffGochT
        TaffGoch
        jantglez,
        Welcome to the SCF!
        If you're talking about longitude/latitude, or theta/rho angular (spherical) coordinates for points on the surface of a sphere, SketchUp does not natively support those coordinate systems. SketchUp expects cartesian (x,y,z) coordinates.
        I typically use a spreadsheet to convert from angle/vector coordinates to cartesian coordinates. I then import the cartesian coordinates into SketchUp, using a '.dxf' data file, or '.csv' file (using a ruby plugin.) Both are text data file formats. SketchUp natively supports the import of DXF files. To import a CSV file, you can download and install the "Cloud_V6.rb" plugin from this page...
        Ruby Library Depot
        ...thanks to Didier Bur. (The plugin is 'zipped' as "Cloud_V6.zip")
        The cloud plugin will import points only (i.e.; a "points cloud".) A properly-formatted DXF file can import points, lines and polygons, but, as expected, is a more-complicated file to generate with a spreadsheet.
        Note that I use these methods for geodesic dome constructions (3D Warehouse - Geodesic Collection)
        If you don't need to cover a spherical area, but only a small patch on the surface (such as earth longitude/latitude), then other means may be available to you. I must, apologetically, leave comments on those potential methods to others, who have more experience importing GIS and longitude/latitude survey data.
        Regards,
        Taff
        "Information is not knowledge." -- Albert Einstein
