    Deleted Shadow Info???
    4 Posts 3 Posters 417 Views 3 Watching
    • Al HartA Offline
      Al Hart
      I started a new drawing, and got an error in one of my ruby files because I was trying to access deleted shadow info. I'll never be able to repeat it again. Here is what happens when I try to access shadow info from the ruby console:
      model = Sketchup.active_model
      #<Sketchup;;Model;0xe789620>
      si = model.shadow_info
      #<Deleted Entity;0xe7872e0>
      It reports the SketchUp Shadow Info as a deleted entity.
      (This was right after starting a new model)
      1. Has anyone ever seen a case where the shadow info was deleted?
      2. Even though it may never happen again, I like to add check to Ruby Files so they don't die when something goes wrong. Does anyone know how to check for a "Deleted Entity". If so, I could avoid trying to access the shadow info when is was deleted.
      Al Hart
      IRender nXt from Render Plus
        RickW
        1. I've had that happen with the Pages object, the Layers object, the Definitions object, and I think the View object. It's a strange situation and I haven't been able to reproduce it consistently.
        2. Did you try the .valid? method?
        RickW
        www.smustard.com
        • scottliningerS Offline
          scottlininger
          Al,
          Are you on a mac or PC?
          • Scott Lininger
            SketchUp Software Engineer
            Have you visited the Ruby API Docs?
          • Al HartA Offline
            Al Hart
            I was on a PC.
            I'll try the valid check. I can create an ordinary deleted entity - by deleting one - but I would still like to know how this state happens.
            Al Hart
