    Follow me rotate?
    5 Posts 3 Posters 544 Views 3 Watching
    • S
      skaught
      I am desperately searching for the follow me rotate plug-in. I keep ending up http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=13014&start=0&st=0&sk=t&sd=a <---here. and I still haven't found the download file.
      Would someone please help me out?
      • soloS
        solo
        Go to the link you provided and the eighth post has a .rar, download and unrar it.
        That's the right plugin you need.
        http://www.solos-art.com
        • S
          skaught
          Do i need any special software to "unrar" it? I have downloaded it, but I am unfamiliar with .rar
          I actually downloaded it a while back but was under the impression that I could just drop it in the plug-ins folder.... If you have already gone through this a million times with other geniuses, maybe you could just point me to a prior post.
          • boofredlayB
            boofredlay
            Hey there Skaught. .rar is a compression file much like a .zip file.
            You can get 7zip here which is an open source program that will open an .rar file.
            http://www.7-zip.org/
            • S
              skaught
              works like magic. Thank you both very much. I can tell it's going to take a little while to be able to use it effectively, but I can already do some things that I couldn't do before. So, thanks again. I will make an effort to contribute time as well.
