    Wanted: Rotate Texture 90d Icon
    3 Posts 3 Posters 458 Views 3 Watching
    • genma saotomeG Offline
      genma saotome
      I not a programmer... I find myself rotating a selected texture 90 degrees all the time and the default GUI menu is pretty inefficient: select the texture and then menu Texture/Position/Rotate/90/Done. Does anyone know where I might find those functions programmed as icon? You know, select the texture, click the icon, and it's done. 7 mouse clicks reduced to 1.
      Ummm, and if it's not already written and is dirt simple to write, might someone write the code? I think it's one of those little things many people would like.
        RickW
        TextureHelper will do this (without the icon) - right-click on face, select "Texture Helper", then click on each face texture you want to rotate - done.
        RickW
        www.smustard.com
        • G Offline
          greatoe
          pretty much looking forward to this ... 7 clicks to 1 ...
