    [IDEA] Particle cloud
    6 Posts 4 Posters 655 Views 4 Watching
      Here's a concept. I don't know if I can be done or not, but I'm just throwing the idea out here and I'm curious to what you lot have to say.
      • You create a volume geometry in any shape. (Closed shape)
      • Make it into a group or component.
      • Then right click and "Create Particle Cloud"
      • The ruby then creates a number of construction points inside the volume. (Of course it'd be nice to have an option window where you set the density and clustering options.)
      • Then you can choose a component, or multiple, which will populate the cloud inserting at the component axis point. (The display of the components can be toggled between geometry, construction points or both.)
      This way we'd have a crude set of particle system.
      The idea comes from when I was using 3DS Max and was playing around with particles. I created smoke by instancing rectangular planes that was always facing the camera (face me components) with a radial gradient from white to transparent. That's just one thing you could do, much more fun stuff could be done with this.
      What's your thoughts?
      • I Offline
        ilay7k
        it remind me union of pointcloud of great D.Bur and archiect's convexhull-addon...
        i like octree3d-manipulation in rhino3d
        it was based at points, which laing at pipe...
        • P Offline
          psychomuffin
          You could make your little clouds, then use this: http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=6913 to randomly place them all in a certain area.
            I had component spray in mind when thinking of this idea. Though, the working of what I propose it still somewhat different.
            • EarthMoverE Offline
              EarthMover
              Ilay7k,
              What ruby are your using for quad modeling viewports?
              Content Creator at Skapeup
                @earthmover said:
                Ilay7k,
                No ruby. It's another application. Rhino. http://www.rhino3d.com/ NURBS modelling.
