    Windowizer4 now available!
    55 Posts 12 Posters 15.5k Views 12 Watching
      chango70
      Hi Rick.
      It is working now. Thanks alot!
      One thing. I can't get it to cut walls still. When I made a 500mm thick wall and tried to use the plugin (i tried 500mm and 1000mm for max wall thickness) it didn't cut a hole through the wall. Am I doing something wrong?
      Cheers
        RickW
        Urgh. Typo on my part. Re-download to get the fixed version.
        RickW
        www.smustard.com
          chango70
          Rick, stupid question but, do I use the same link Smustard sent me to Re-download? I tried that and it say it can't verify my email.
          • EdsonE Offline
            Edson
            @rickw said:
            Looks like I've fallen prey to the infamous Safari-SU-Ruby bug. 😞
            I think I know how to work around it, but it will take some time.
            I'll post a notice when the updated files are ready to download.
            Thanks,
            looking forward to it.
            http://www.mahfuz.arq.br
              RickW
              This may seem like a dumb question, but did you use the correct email address? Some people have a seldom-used email address for PayPal, and sometimes forget that's the one to use to access the download.
              RickW
              www.smustard.com
                RickW
                To recreate a lost post:
                I have uploaded an update to Windowizer4 that fixes an obscure bug (could cause a bugsplat when using Windowizer4 inside a group with "Front only" set to "Yes").
                The next planned update will include a right-click-menu option to start Windowizer4, and I hope to have style exporting/importing done as well.
                RickW
                www.smustard.com
                • utilerU Offline
                  utiler
                  Uploaded the update to smustard, Rick?
                  Just Curious...
                  • jujuJ Offline
                    juju
                    Rick, is it possible to mail a memo to people who've bought scripts when a newer version is available? If I didn't pass through here I wouldn't have known about the update (bug fix), and I bought & DL'ed on 11/11/08.
                      RickW
                      Correct - uploaded to Smustard.
                      Yes, I intend to do that this weekend yet.
                      RickW
                      www.smustard.com
                      • jujuJ Offline
                        juju
                        Sweet! I've been trying to download the latest version through MySmustard but for the some or other reason it is not working at the moment, I also tried downloading using the download URL given in the e-mail I got from Smustard, but this too seems not to be working. I'll try MySmustard again later, I hope it'll be working then.
                        • jujuJ Offline
                          juju
                          Got the latest update eventually. MySmustard is such a sweet plugin! If only there was something similar for the other plugins... 😞
                          • EdsonE Offline
                            Edson
                            i could not get the original W4 to work on my mac but your latest update did the trick. there is no more need to use .m, .mm or .cm for metric units. W4 assumes the file units.
                            a wish or two: why not have at least one transparent material in the glass material drop list? would it be possible to access the paint bucket when defining the material for the frame and glass?
                            thanks for this great plugin.
                              RickW
                              While I haven't found a way to do an "eyedropper" from a dialog, remember that the W4 dialog is modeless - you can use the paint tool's eyedropper to select a material from the model and see what its name is in the Materials dialog, then select that same material from the dropdown in the W4 dialog.
                              I know that's not ideal, but it's the best available option for now.
                              RickW
                              www.smustard.com
                              • EdsonE Offline
                                Edson
                                rick,
                                having wxSU installed causes conflicts with windowizer4 (the dialogue appears blank) and immediate crashes after invoking it. after removing wsSU everything went back to normal.
                                but since wxSU is necessary for RandomPainter to work, perhaps there is something you can do that would allow both scripts to be installed at the same time.
                                regards.
                                  RickW
                                  I had noticed problems with wxSU as well (one reason I didn't adopt), but not specifically with Windowizer4. I'll have to dig in and see what I find out.
                                  Thanks,
                                  RickW
                                  www.smustard.com
                                  • 3 / 3
