    Request for copper texture
    8 Posts 4 Posters 4.3k Views 4 Watching
    • EdsonE
      Edson
      would anyone be kind enough to provide me with a copper texture? i am doing a project whose steel structure will be faced with copper sheets but i do not seem to be able to find a good texture for it.
      thanks.
      http://www.mahfuz.arq.br
      • W
        watkins
        Dear Edson,
        As a stopgap, the rust texture here:
        http://www.sketchucation.com/forums/scf/viewtopic.php?f=40&t=13226&st=0&sk=t&sd=a&start=30
        might do.
        Regards,
        Bob
        • W
          watkins
          I have these two copper surface images. Perhaps someone could play around with them to make them tile better.
          One at least came from:
          http://www.spiralgraphics.biz/packs/metal_robust/index.htm
          Try the copper_tarnish here
          http://www.spiralgraphics.biz/packs/metal_corroded/index.htm
          Hope this helps.
          Regards,
          Bob
          • EdsonE
            Edson
            thanks, bob. the top one is very much what i had in mind. perhaps they will work without much refinement as i intend to use them as 30cm wide (1 foot) panels.
            regards.
            edson
            • R
              remus
              Might be a bit late, but theres some good quality copper panelling textures here: http://www.cgtextures.com/texview.php?id=5798&PHPSESSID=6dd2fa3387cc9dfe1756be02e54de465
              • EdsonE
                Edson
                thanks, remus. not late at all.
                • I
                  Iglesias
                  Due to a problem in the server; here you are the copper textures, and a few more of stones.
                  textures.rar
                  piedras.rar
                  • EdsonE
                    Edson
                    thanks again, josé manuel. i had already downloaded the textures before the failure.
