    BAD SU MAGIC hit me AARGGGgggg PLS HELP me pls :-( ugghhh
    4 Posts 2 Posters 469 Views 2 Watching
      bhnida
      hello to all helpfull and ALL time white magic SU ferries ๐Ÿ˜„
      i had bad macig on my SU the wizzard of NOrectanglefaces hit me and all my rectangles i am drawing
      has no faces anymore ? and cant get it back no matter what i do even redrawing with a line nothing helps
      i am saing the wizzard of NOrectangelfaces as all others do still have the surfaced like circle and poligone still works well.
      wich herbs ore magic i need to blow in the face of ugly bad magic to defeat it ?
      thanks bernhard
        Ross Macintosh
        Hi Bernhard
        I was wondering if you accidentally switched your SketchUp display mode to 'wireframe'? In that mode all faces stop displaying and all you will see is the edges. But if you are still seeing some faces that wouldn't be the explanation.
        Can you attach the model or a screenshot? Doing that will most likely get you an answer - one that has nothingto do with magic.
        Regards, Ross
          bhnida
          no unfortunatly not all otehr faces in models are there
          also in circle and poligone it works ONLY IN RECTANGLE it has no faces anymore. ๐Ÿ˜ฎ
            bhnida
            forgot to tell we had once the same dogy VERY MUCH SAME ๐Ÿ˜„
