    {REQ} Grow selection
    2 Posts 2 Posters 963 Views 2 Watching
    • EarthMoverE
      EarthMover
      Is it possible to create a ruby that will grow a selection. In Modo, if you select two edges or polygons and then hit the up key, you can grow the selection in the direction of your 2nd selection. I was wondering if this were possible in sketchup.
      Another example would be if you select an edge on an arc that is made of many segments. It would be nice to be be able to select two edges and then just press up, until you've selected all the connecting edges along the path, instead of fumbling with the select tool.
      Selection in general is rather frustrating in SU, once you're used to other apps. I hope SU7 will address this.
      Content Creator at Skapeup
      • bagateloB
        bagatelo
        Modo is a fantastic software. But I prefer Sketchup for being accustomed. One day still desire to learn to use Modo in a professional way. The tools of selection of Modo are fantastic, as to Loop Selection. Developers of Sketchup should analyze the Modo more closely.
