    Rotate a texture
    9 Posts 5 Posters 2.0k Views 5 Watching
      Matt666
      Hi all !
      I don't understand how to rotate a texture in ruby... I suppose I have to use "UV helper" function, but I don't know how... And "get_front_UVQ" function returns a point... Maybe someone can help me ?
      Thank you !
      Frenglish at its best !
      My scripts
      • P Offline
        psychomuffin
        Textures have driven me craxy so many times in SU. I really hate how sometimes groups will rotate the texture, or sometimes, the object will rotate, but the text keeps it's orientation, lol. SU does not have a good mean of using textures it seems thus far, I would love a good plugin that can make this kinda stuff easier.
        • N Offline
          NewOne
          Here is a scipt that rotates a texture on a face by a custom angle.
          For now, the script works just for faces in xy plane (red-green) but it can be a usefull example to understand how to position a texture on a face.
          The UV helper retrieves the vertex coordinates. So, if you have a hexagonal face, you will have 12 points (6 vertexes). But position_material method uses maximum 8 points (4 vertexes)... This is because Open GL treats any surface as a composition of triangles or quadrilaterals (sorry if misswriten). This is why i don't know yet how to make the script working for faces oriented arbitrary (not normal on an axis). I use the entitie's boundingbox as a reference.
          For better understanding of what I've done, see this image http://bayimg.com/bALMEaABJ
          require 'sketchup.rb'
          def rotate_texture
          prompts = ["rotation angle "]
          value = [0.0]	#use float for better precission
          result = inputbox prompts, value, "Texture Rotator"
          return if not result
          angle = result
          ox = Math.cos(angle[0].degrees) #projection coefficient
          oy = Math.sin(angle[0].degrees)	#projection coefficient
          selected = Sketchup.active_model.selection[0]
          	if( selected.is_a? Sketchup;;Face ) #check if you selected a face
          		boundingbox = selected.bounds
          		material = selected.material
          		texture = material.texture
          		bw = boundingbox.width
          		proj_x = ox*bw
          		proj_y = oy*bw
          		tex_w = (texture.width).inch
          		ratio = bw/tex_w	#calculate the ratio between image dimension and boundingbox dimension,
          							#to preserve same tiling
          		pts = []
          		pts[0] = [0, 0, 0]
          		pts[1] = [proj_x, proj_y, 0]
          		coords = [pts[0], [0, 0], pts[1], [ratio, 0]]
          		selected.position_material(material, coords, true)	#here you put the material using new coordinates
          	else
          	UI.messagebox "You must select a face !"
          filename="texture_rotator.rb"
          if !file_loaded?(filename)
          	plugins_menu = UI.menu("Plugins")
          	if plugins_menu
          		plugins_menu.add_separator
          		plugins_menu.add_item("Rotate texture by angle") {rotate_texture}
          	file_loaded(filename)
          Hope it's helpfull not hellpful πŸ˜›
          regards!
          • P Offline
            psychomuffin
            Please excuse my lack of understanding, but how does one take the code you provided, and turn it into a plugin? Does it need compiling or anything? I really don't know anything about ruby... sadly.
            • N Offline
              NewOne
              Copy all that text and paste it in a notepad file. Rename that file with " texture_rotator.rb " (see the last lines of the code that add a entry in Plugins menu) and put your newly created file in the Plugins folder of SU.
              Carefull with copying to not miss something.
              Enjoy!
              Sketchup have built-in ruby interpreter, so what you need is just the code. Ruby is an interpreted language (like Fortran if you want), not a compiled one like C.
              Be aware that this script rotates the texture on the face, not on the component (or group). So you must apply the material directly on face.
                Matt666
                NewOne and me try to make a script which rotate textures automatically. See this post to understand what I want...
                My scripts
                  tomasz
                  Hi NewOne,
                  I am glad to see someone here who can cast some light into my dungeon of texture coordinates. πŸ˜„
                  You have mentioned about UVHelper but you are not using it in the script. I would like to learn how to use it efficiently also with nested faces and will contribute to this thread as much as I will be able to.
                  Tomasz
                  • N Offline
                    NewOne
                    You are right! I didn't used UV helper and you have the answer why in those posts. As I seen since now, for SU, the priority is the tiling of texture on surface, although you enter the size of the tile in texture editor. So, that's why we need to know the overall dimensions of the face. If the face is normal-to-axis is simple: you use face.bounds. But for a randomly oriented face we must calculate the vertex distance.
                    I have an ideea: it came on-the-fly πŸ˜„... to use UV helper to retrieve the position of all vertexes of the face. Then calulate the projection from boundingbox center to farthest vertex in two perpendicular directions.
                    center = face.bounds.center
                    Then, having this, is easy to know the overall dimensions of the face and the ratio (ratio = fasce_dimension / texture_dimension) to preserve same tiling when rotating. If you don't do this, the texture will shrink. texture shrinks if don't preserve the ratio
                    After that, one of the vertexes is rotated around the normal to face with desired angle. And that's how the texture can be rotated on randomly oriented face !
                    this is a strange shape face, to make things messy ;)
                    Or, maybe it's a easier way to do this... I mean to work on triangulated or quadrilateral faces, but there Open GL must be used, I think.
                    Some suggestions from The Big Ones? πŸ’š
                      I'm working on mirroring the texture and UV mapping of front faces to the backside. Anyone got any idea on how to do that?
