    Transparency/Opacity in SketchUp6/Google Earth4.3
    Scheduled Pinned Locked Moved Google Earth
    4 Posts 3 Posters 2.6k Views 3 Watching
      ChaosDesign
      Good evening, where ever u r.
      I couldn´t find any answer in other (german) forums. So, please excuse my english, but i try to explain my problem as good as possible.
      I have a problem with a SketchUp6 model (the free non-pro version) in the recent Google Earth version 4.3.7284.3916 (beta).
      I´ve constructed a model, a building with glass facade outside and walls inside. The glass facade encloses the whole building. (It´s not my first model, so i´m a little experienced: http://sketchup.google.com/3dwarehouse/cldetails?mid=87a5644bc5490aac8056ddd04e5ca0f3 )
      The building is hollow from the inside. The outside facade is transparent and has a photo-texture (jpeg) with 70% opacity. IN this building there are some walls, which have also a photo texture (jpeg), with no opacity.
      In SketchUp6 the inner wall is to be seen throughthe transparent glass facade, from every angle. That´s how it supposed to be: http://picasaweb.google.de/ChaosDesignKS/Temp?authkey=pro_QZRsiAc#5257274296494849666
      However, if I export the model as a kmz4 file to the recent Google Earth 4.3, only the transparent glass facade of the building is to be seen (with photo texture), BUT NOT the inner walls !!!
      http://picasaweb.google.de/ChaosDesignKS/Temp?authkey=pro_QZRsiAc#5257273738923125138
      From the outside it looks completely hollow inside. Only if I „zoom in“ and „fly“ into the building, the inner wall is to be seen.
      As u can c in the linked pictures, the problem does not exist with the Google Earth version 4.2.0205.5730 ! (So it can´t be a problem with the jpeg/png-transparency ?!)
      Now my question: WHY ❓
      And above all, how to make the inner walls also to be seen in 4.3 version from the outside throughthe glass facade ???
      Thank you for tips, hints and links
      ChaosDesign
      P.S .: The same problem exists with this model:
      http://sketchup.google.com/3dwarehouse/details?mid=5a33a923094d89903bf73821118a789b
      The internal painting is not to be seen from the outside through the transparent glass windows, too. But when I fly into the model, the picture is to be seen, too... strange 😕
        Hi ChaosDesign,
        This is just a stab in the dark but try to apply the transparent image also to the inside (the back, blue) of the faces.
        There used to be (and maybe there is still) a glitch with the SU > GE export when transparent materials "blocked" the materials behind them and you couldn't see them.
          ChaosDesign
          What should i say, Gaieus... ???
          THANK YOU - THANK YOU - THANK YOU and... NAGYON KÖSZÖNÖM (?) !
          Thank´s a lot ! It works !
          I´ve textured the backside of the glass facade also with the transparent texture and exported the model to Google Earth... it´works... the inside is to be seen from the outside throughthe glass facade
          ChaosDesign
            Great - glad that it solved the problem! 👍
