    Line on surface removal plugin (Request)
    8 Posts 5 Posters 1.3k Views 5 Watching
    • P Offline
      Psyco_BoB
      Anyone know of a plugin that can remove unnecessary lines from a flat surface?
      What i want to do is to import a dwg file into SU. When I do this the entire model is segmented into groups and most of the faces have unnecessary lines on it as if it is a curved surface.
      I just want to know if there is a simpler way of getting rid of these lines other than individually deleting the lines.
      A "one-click" solution you might say.
        remus
        This seems as if it will do the job you want: http://www.sketchucation.com/forums/scf/viewtopic.php?f=10&t=9011&p=58654#p58654
          remus
          sorry, cant help you with that one. Hopefully someone more knowldgeable will be able to answer your question.
          • P Offline
            Psyco_BoB
            Thanx.
            But if i try to load the file the following message appears.
            Error Loading File cleanup.rb
            undefined method `file_loaded?' for main:Object
            Another Idea by any chance?
            • P Offline
              Psyco_BoB
              Thanks anyway. πŸ˜‰
                basic.woodworks
                Don't know if you ever got your answer or if this may be the one you're looking for but you can try this:
                deletecoplanaredges.rb
                Be aware: Try not to use it on a large number of rounded or curved edges. It may delete some of the edges (don't know why) and depending on the amount of lost detail, you may not be able to under the history enough to get it all back. A thought may be to save your model prior to using the script. That way if you lose too much... you've not really lost anything.
                "The greatest mistake a person can make is to be afraid of making one." (Elbert Hubbard)
                  sepo
                  Maybe straylines.rb from Smustard can do a job? It is free ruby.
                  • Chris FullmerC Offline
                    There is an option when you import dwg files to "delete coplanar edges" or something like that. Just use that. It works good,
                    Chris
                    All my Plugins I've written
