    Importing files from autocad
    2 Posts 2 Posters 551 Views 2 Watching
    • S
      set designer
      when i import a drawing with a curve from autocad into sketch up, the curve comes out faceted in sketch up,
      how do i prevent this , or fix this
      • TaffGochT
        TaffGoch
        set designer,
        You should note that SketchUp doesn't actually do curves. All circles, arcs, bezier curves, etc. are composed of straight-line entities.
        After import, you can select a curve and change the number of line segments, if you need a smoother 'curve.' (At least, that is usually reported as effective.) After selection, look in the 'Entity Info' dialog box, and therein change the number of segments.
        Taff
        "Information is not knowledge." -- Albert Einstein
