    How to see thumbnail with sketchup files ???
    8 Posts 3 Posters 2.7k Views 3 Watching
    • H Offline
      huyvuvn
      I'm using windows xp64 bit sp2
      I can not see the thumbnail of sketchup files? how can I see that ? plz help me , thanks πŸ˜„
      http://img183.imageshack.us/img183/5199/screenhunter001xw4.jpg
      happiness on the way, not in the destination.
      • ArcA Offline
        Arc
        1. Click "Start" > "Run."
        2. Type "cmd" in the Open box and click "OK."
        3. Navigate to the SketchUp directory, which is typically located at C:\Program Files\Google\Google SketchUp 6\
        4. Type "regsvr32 thumbsup.dll" without quotes and hit Enter.
        • TaffGochT Offline
          TaffGoch
          Unless it has been updated, I don't think the "thumbsup.dll" will work on 64-bit systems (according to the SketchUp developers):
          http://www.sketchucation.com/forums/scf/viewtopic.php?f=15&t=9988&p=64407#p64407
          Can't hurt to try, though. You might also check the rest of the above-linked discussion, to see if there's something else that might work.
          Taff
          "Information is not knowledge." -- Albert Einstein
          • TaffGochT Offline
            TaffGoch
            Also, see the "Other Known Issues" section, in the Google SketchUp Release Notes. There are a couple of references to not being able to see thumbnails:
            http://docs.google.com/View?docid=ajg9d7mmp8rt_4gp925h
            The above link refers to the Microsoft Knowledge Base article...
            http://support.microsoft.com/kb/895561
            ...which provides a partial work-around.
            Note that the workaround suggests that the 32-bit version of the "Windows Explorer" (file directory) be used, and describes how to do so. This will only affect the folder/file directory display, and will not impair or change the running of the remainder of the 64-bit system.
            Taff
            • H Offline
              huyvuvn
              thanks much but it not working...
              http://img355.imageshack.us/img355/9624/screenhunter001nr2.jpg
              http://img65.imageshack.us/img65/346/screenhunter002mh6.jpg
              • H Offline
                huyvuvn
                help me !
                • TaffGochT Offline
                  TaffGoch
                  ":3br823pt]help me !
                  Well, I tried, but didn't see any feedback from you regarding my two posts...
                  Were they not of any use?
                  • H Offline
                    huyvuvn
                    thanks man but I've tried and that's not work 😞
                    however , the thumbnail is not a big problem πŸ˜‰
