    How to remove
    4 Posts 3 Posters 657 Views 3 Watching
    • kenK
      ken
      OK, I tried the program Waybe. It doesn't do what I need, so now I want to get rid of the program. I have removed the script file and the zip file. However, I still get this message.
      Any suggestions.
      Thanks in advance
      Ken
      OOPS! Never mind, found the directory. W Tools.
      However, still looking for a good unfold program. Jim works great, just would like to be able to pick the plane to unfold to.
      Thanks again
      Ken
      • J
        Jim
        As a work-around, you can create a rectangle anywhere - it does not need to be attached to your unfold geometry - and select it as the last unfold plane.
        • TaffGochT
          TaffGoch
          Who knew! How great is that?
          I've been rotating the 'flattened' results, using SketchUp's 'rotate' tool. Thanks for the tip, Jim. (You really should add it to your blog's 'Unfold' page.)
          Taff
          "Information is not knowledge." -- Albert Einstein
          • kenK
            ken
            Jim
            Yep, that what I do now and it does the job well and quite happy with the results.
            Thanks for the script
            Ken
