    Giveaway of the Day - Inpaint
    extensions
    1 Posts 1 Posters 818 Views 1 Watching
    • J
      johnsenior1973
      http://www.giveawayoftheday.com/inpaint/
      Only available for another 22 hours.
      *Giveaway of the Day - Inpaint
      October 7, 2008Delete any unwanted object from your photo, such as extra power-line, people, text… The program will automatically inpaint the selected area to erase it. Inpaint reconstructs the selected image area from the pixel near the area boundary. Inpaint may be used to remove undesirable objects from still images.
      If some unexpected object spoils an otherwise good photograph, Inpaint may be used to remove it. Simply select the object. No need for fiddly messing about with the clone tool!
      It is alarmingly simple to use. Draw a selection around the object you wish to remove from the picture, and run smart remove selection. Inpaint will fill the selection area with intelligently generated texture drawn from the surrounding image data.*
