    Photomatch error when rendered in kerkythea
    extensions
    2 Posts 2 Posters 1.8k Views 2 Watching
      mrmar975
      Hello to whom can help out with a photo match to KerkyThea error.
      I modeled a coffee table from a photo match jpg and then rendered it to test out some ideas before I bring it into my classroom (I teach architecture and we use sketchup and kerkythea). I was wondering why this texture showed up the way it did in kerkythea. Does Kerkythea have the ability to import that information from a photomatch?picture file of incorrect render
        blugarero
        Make sure that when you export the scene you check the box where it says: Export photomatched. Then it should work. However, if you have a landscape scene with smooth suraces that are photomatched, then these surfaces will be sharp, since kerkythea exports each triangle from a photomatch as a different object, in this case.
