    Push Pull Finesse
    2 Posts 1 Posters 422 Views 1 Watching
    • J
      Jim57
      It seems that with Sketchup you have to think a lot about how to start to get to where you want to go.
      I am drawing my building so I can extract some drawings for roofers. I started with the roof lines, then wall elevations, chimney, etc. Then I started trying to Push/Pull the walls into thickness, so I could show people sections, and things got interesting.
      If I draw a rectangle, I have no proplem Pushing it into a rectangular solid. But if I draw a cornice and the wall behind it, the wall just does not want to Push into a volume. It seems that once a plane intersects the wall, I can't Push unless I somehow manage to keep the corner. What happens is I move the wall, but I can't leave the original face in place.
      I've managed to hack my way through the chimney by pulling faces, drawing lines, pulling faces, again and again. I don't want to go through that again with the large wall in my attachment.
      I thought this must be a glitch on my computer, so I've cold restarted. I still get the same thing. Any hints?
      Thanks In Advance,
      Jim
      Icarus Roof.skp
      • J
        Jim57
        Wow, that little trick ("option click" on my Mac) is great. Thanks.
        I would normally start with the floor plan, but in this case I don't know, and don't need to know, the exact size of the building or its height, just the critical dimensions around this wall, chimney and roof. I figured it would be easier if I could just draw the important stuff and let the rest sort itself out.
        Best,
        Jim
