    Toggling Continuous Line
    4 Posts 3 Posters 600 Views 3 Watching
    • J
      Jim57
      When I'm using the Line tool, sometimes the line continues and sometimes it doesn't. That is, sometimes after I draw the first line segment, the endpoint stays selected as the starting end of the next segment.
      Usually SU makes the wrong choice for me at the moment— sometimes I want to draw one and sometimes I'm working on a continuous outline. How do I toggle this feature?
      Thanks,
      Jim
      • D
        dylan
        If you prefer to work with the setting switched on you can also hit the spacebar to deselect the line command.
        http://dmdarchitecture.co.uk/
        • J
          Jim57
          Actually, I'd love an easy way to turn it off AND on. Sometimes I need it, sometimes I don't.
          JIm
          • GaieusG
            Unfortunately even when the option Jame mentioned is turned ON, the continuous line drawing wont go on when you have just finished to close a face for instance and there is no way you can force/encourage/suggest/hint SU to continue drawing.
