    Push/Pull Multiple Items?
    4 Posts 4 Posters 4.1k Views 4 Watching
    • G
      greengenuity
      I am building a handrail for a balcony and need to use the push/pull tool to make the vertical spindles three-dimensional. Is there a way to select all 200+ spindles and pull them up at once, rather than do them individually? I am able to select them with the arrow tool, but when I click the push/pull tool, they are no longer blue. Thanks!
      -Chris
      • R
        remus
        You cant push/pull multiple things at the same time, although it sounds like you should be able to pull one up and just use the array bit of the move tool to copy it.
        • Jean LemireJ
          Jean Lemire
          Hi Chris, hi folks.
          Try using components. That way, pulling one instance will modify all others in one shot.
          If not feasible, see the SU file in this thread for ideas:
          404 Not Found
          (www.sketchucation.com)
          I did it a while ago for another purpose but the basic idea is the same.
            Seems you can with the Joint Push Pull plug by Fredo666 πŸ˜’
