    πŸ€‘ SketchPlus 1.3 | 44 Tools for $15 until June 20th Buy Now
    [REQ] follow me rotate
    15 Posts 10 Posters 5.8k Views 10 Watching
      silver_shadow
      hi guys.. i wanna know if this is possible...of if there is a tool like this..
      to have a shape, put in in a follow me path but it needs to rotate say by a factor...like divide by a factor, or multiply by a factor.
      If the factor part is not possible, is the follow me with any rotate cycle possible. if so...pretty please πŸ˜„
        there is the "Grow" by Tig who give Copy rotation, movement and size in the same time but not the Follow me πŸ˜‰
          silver_shadow
          not quite.... see i want to extrude a profile along a path, but give it a twist. πŸ˜„
            Hi Jacue,
            Not sure if this is what you are fter but there is a plugin called RotaPushPull in the Ruby library depot.
              silver_shadow
              maybe this will clarify a bit..
              say if you want to make a cable...or a rope or a wire...couldnt this be cool
              so instead of having this way below...you have the thing rotated making it look more believable to be a wire
              http://i185.photobucket.com/albums/x165/hondsekont/test.jpg
                Try Moi Moment of Inspiration πŸ˜‰ Same easy use than SU πŸ˜„
                Sweep 2 Rails is for you, and you can export in SKP format in Beta v 2.0 β˜€ (only for owners of the V1.0) πŸ˜’
                By JBShorty
                http://forums.polyloop.net/attachment.php?attachmentid=26384&d=1221739637
                As you have some plug like this, + a function Curve Array along a path mix it and you will have some old cables πŸ’š
                http://moi3d.com/forum/get_attachment.php?webtag=MOI&hash=5485972e8df3e3fb10ff8d0ff176deff&filename=toroidal_helix_screenshot.jpg
                • W Offline
                  wikii
                  just finished one
                  http://www.sketchupbbs.com/thread-13577-1-1.html
                  .jpg
                  • bigstickB Offline
                    bigstick
                    Er, I'm not sure what this link relates to. The whole page is Chinese, and to be honest, on an English Language forum the overwhelming majority of us aren't able to read any of this.
                    If there is a Ruby plugin which can do this (as your post seems to suggest), it would be great if you could post it here. I'm sure loads of people would find it really useful.
                    • EarthMoverE Offline
                      EarthMover
                      Yes, Wikii, it would be nice to share with us the ruby you've created. I tried to translate and navigate the BBS page and even tried to register in order to have a try with the ruby, but with no luck. Telling us you've created this ruby without sharing is such a tease! 😞
                      I could really use this for one of my current projects. Thanks in advance.
                      Content Creator at Skapeup
                      • soloS Offline
                        solo
                        I too would like to see such a ruby in action. However the only way I can see that possible is a 3rd party app, below is an example using an imported SU chord and twisting it using Hexagon2.2
                        http://img201.imageshack.us/img201/2671/heximagezy8.jpg
                        http://www.solos-art.com
                          Jim
                          I split the plugin from this request thread.
                          301 Moved Permanently
                          (www.sketchucation.com)
                          • soloS Offline
                            solo
                            There is another ruby, however I do not remember where i got it or who made it. It's called 'rotated push pull' below is how it works.
                            http://img184.imageshack.us/img184/95/rotatedpushpullsf0.gif
                              Hm. That was my first idea, too. See above.
                                boilingsnow
                                Yes, I got this ruby too. But it can't fellow a curved or urser difined path.
                                  MrGoon
                                  Hi all, has anyone out there been able to get "Follow Me Rotate" to work on SU17.
                                  I have tried many different downloads but no luck yet.
                                  Any help would be awesome
                                  Many thanks, Murray
