    Hanoi Project
    35 Posts 15 Posters 3.2k Views 15 Watching
    • H Offline
      howardhong
      nomeradona,
      partially youre right.
      freeagents method is very difficult, but works very nice with low polygon.
      Xfrog can export .3ds, so su import it without any process.
      all of xfrog trees are very nice for vfsu and it can be modified.
      anyway, ill go to DaNang as construction manager.
      thanks for your concern.
      • N Offline
        nomeradona
        cool!!! wow your going to danang.. cool. im based at saigon. i love danang particularly the old town of hoi an. it has character like hanoi. i love the old city of hue too. good luck!!!
        so what is your workflow with xfrog then, do you export them in 3ds and import them back to su in 3ds too. how about the texturing them. i was told that the texturing is the problem. can you explain your workflow.
        visit my blog: http://www.nomeradona.blogspot.com
        • H Offline
          howardhong
          heres my process of SR1.
          1.copy tif and shorten that name. sometimes truncated when export.
          2.copy tif to jpeg and prepare B/W alpha.
          3.change tif file name applyed to trunk and leaf in Xfrog.
          4.export 3ds and check scale option.
          5.import 3ds in SU and explode one time.
          http://i241.photobucket.com/albums/ff294/howardhong/p1.png
          6.check the size of tif file in material tab of SU (25.4 x 25.4).
          http://i241.photobucket.com/albums/ff294/howardhong/p2.png
          7.apply jpeg to diffuse of VFSU material tab and apply alpha too.
          http://i241.photobucket.com/albums/ff294/howardhong/p4.png
          8.change the size of JPEG (254 x 254) in materialtab of SU to 25.4 x 25.4.
          http://i241.photobucket.com/albums/ff294/howardhong/p3.png
          9.apply VFSU material to model. dont be scared with the appearance of su model.
          10.render.
          • N Offline
            nomeradona
            thanks howard. i hope you will send this tutorial to asgvis. i will try this workaround. thansk again.
            • H Offline
              howardhong
              As you know, materials of vfsu SR1 and SU is related each other.
              so you cant control materials of SU.
              if you use vfsu V1., all the process is same as above, but
              and move opacity slider to 0 all the way.
              because it makes materials of SU invisible when rendered.
                skyscraper100
                great work sir! galing
                The way you think Creates reality for yourself.
                • N Offline
                  nomeradona
                  wow very seldom to meet filipinos here. thanks bro bro for dropping by.
                  • W Offline
                    WEB
                    That is a lovely rendering and a handsome building.
                    One thing: the mind's eye does not see the vertical perspective in relatively short buildings; so when one looks at a photograph or rendered image that does show it, the building seems somehow wrong. Architectural photographers use a shifted lens to keep the film vertical. Your renderings might look better, even though they would be technically wrong, if you could somehow achieve the same result.
                      tomislavm
                      congratulations
                      • N Offline
                        nomeradona
                        will take note of your excellent observation.
                        • N Offline
                          nomeradona
                          salamat bro. thank you.
                          • F Offline
                            FoXar
                            Looking really good, I like the tree you added very much!
                            Keep up the work ;]
                            • 3 Offline
                              3lii
                              Good job
                              thanks for sharing
                              • N Offline
                                nomeradona
                                Keep up the work ;]
                                thank you very much foxar
                                • N Offline
                                  nomeradona
                                  @3lii said:
                                  Good job
                                  thanks for sharing
                                  yeap my pleasure bro.
                                  • 2 / 2
