    Hanoi Project
    35 Posts 15 Posters 3.5k Views 15 Watching
    • N Offline
      nomeradona
      @howardhong said:
      after tens of thousands times of trying, i got this images using both of vfsu.
      http://i241.photobucket.com/albums/ff294/howardhong/bl01y.jpg
      we can find very nice trees in xfrog trees.
      howardhong,
      at the moment i am still thinking to get xfrog trees. after seeing all you guys using it and now your attach example too, i am sold now by this idea. it any case, i will knowck your door if i have problem. but it will be very expensive because there is no direct workflow to Sketchup. Freeagen said you need to remap either with max or cinema4d. what's the point of buying cinema4d or max to remap the whole thing then. i know that i still have to depend at the moment with other trees.
      kwisten,
      pleasure to welcome you here in vietnam, though im not vietnamese, but i have seen a lot of this country and i will say to you its really agood place to have your holiday.
      im now trying to explore
      • H Offline
        howardhong
        nomeradona,
        partially youre right.
        freeagents method is very difficult, but works very nice with low polygon.
        Xfrog can export .3ds, so su import it without any process.
        all of xfrog trees are very nice for vfsu and it can be modified.
        anyway, ill go to DaNang as construction manager.
        thanks for your concern.
        • N Offline
          nomeradona
          cool!!! wow your going to danang.. cool. im based at saigon. i love danang particularly the old town of hoi an. it has character like hanoi. i love the old city of hue too. good luck!!!
          so what is your workflow with xfrog then, do you export them in 3ds and import them back to su in 3ds too. how about the texturing them. i was told that the texturing is the problem. can you explain your workflow.
          • H Offline
            howardhong
            heres my process of SR1.
            1.copy tif and shorten that name. sometimes truncated when export.
            2.copy tif to jpeg and prepare B/W alpha.
            3.change tif file name applyed to trunk and leaf in Xfrog.
            4.export 3ds and check scale option.
            5.import 3ds in SU and explode one time.
            http://i241.photobucket.com/albums/ff294/howardhong/p1.png
            6.check the size of tif file in material tab of SU (25.4 x 25.4).
            http://i241.photobucket.com/albums/ff294/howardhong/p2.png
            7.apply jpeg to diffuse of VFSU material tab and apply alpha too.
            http://i241.photobucket.com/albums/ff294/howardhong/p4.png
            8.change the size of JPEG (254 x 254) in materialtab of SU to 25.4 x 25.4.
            http://i241.photobucket.com/albums/ff294/howardhong/p3.png
            9.apply VFSU material to model. dont be scared with the appearance of su model.
            10.render.
            • N Offline
              nomeradona
              thanks howard. i hope you will send this tutorial to asgvis. i will try this workaround. thansk again.
              • H Offline
                howardhong
                As you know, materials of vfsu SR1 and SU is related each other.
                so you cant control materials of SU.
                if you use vfsu V1., all the process is same as above, but
                and move opacity slider to 0 all the way.
                because it makes materials of SU invisible when rendered.
                  skyscraper100
                  great work sir! galing
                  The way you think Creates reality for yourself.
                  • N Offline
                    nomeradona
                    wow very seldom to meet filipinos here. thanks bro bro for dropping by.
                    • W Offline
                      WEB
                      That is a lovely rendering and a handsome building.
                      One thing: the mind's eye does not see the vertical perspective in relatively short buildings; so when one looks at a photograph or rendered image that does show it, the building seems somehow wrong. Architectural photographers use a shifted lens to keep the film vertical. Your renderings might look better, even though they would be technically wrong, if you could somehow achieve the same result.
                        tomislavm
                        congratulations
                        • N Offline
                          nomeradona
                          will take note of your excellent observation.
                          • N Offline
                            nomeradona
                            salamat bro. thank you.
                            • F Offline
                              FoXar
                              Looking really good, I like the tree you added very much!
                              Keep up the work ;]
                              • 3 Offline
                                3lii
                                Good job
                                thanks for sharing
                                • N Offline
                                  nomeradona
                                  Keep up the work ;]
                                  thank you very much foxar
                                  • N Offline
                                    nomeradona
                                    @3lii said:
                                    Good job
                                    thanks for sharing
                                    yeap my pleasure bro.
                                    • 2 / 2
