    My first work
    13 Posts 9 Posters 1.2k Views 9 Watching
    • P Offline
      pcsalgado
      Hi bros, this is my first work so i would like you to comment as much as possible... i think the rendering tme is very high (about 1:30h)and the result is not so reallistic... besides, there are some white spots in it that i don't know what are.... i've used vray!
      can you help me??? thanks guys!
      ![menor].jpg](/uploads/imported_attachments/MZZI_menor.jpg)
        remus
        Post up some pics of your work and it'll be a lot easier to give you tips and advice.
        • P Offline
          pcsalgado
          this is the only pic i've got till now... another one is comming up and i'll post here...
            mateo soletic
            If this is Your first work all I Can say at this moment is Congratulations. 👍
            Concept Illustrations
            • P Offline
              pcsalgado
              thanks man...
                chango70
                Oh man! Done like a pro. 👍
                  JuanV.Soler
                  what render Engine did you use ?
                  not IDX no ?
                  • P Offline
                    pcsalgado
                    not IDX no ?
                    juan, i've used vray with irradiance map on the primary engine and light cache on the secondary... why do you ask? what is IDX?
                    chango70, thanks for the good words man!!!
                      remus
                      On to those tips i promised.
                      Firstly i think the composition of your first render is a bit weird, namely theres that big what patch on the right hand side. Changing the camera angle to get rid of the big blank spot will help things a lot.
                      Secondly the image is very bright, you might be able to tone it down a bit in photoshop or similar. If that doesnt work its probably worth making a few of the materials a bit less shiny.
                      As for the spots, im not entirely sure what they are, my best guess would be that they are the reflections from the spotlights you have in your scene.
                      Overall they are very good renders though!
                        JuanV.Soler
                        I am talking about the Free IDX Renderer for Sketchup
                        it is quite quick.
                        there ia a thread about it http://www.sketchucation.com/forums/scf/viewtopic.php?f=15&t=12168
                        I say it for the long time of rendering you were refering to.
                        and I was guessing if you could get those effects with that engine.
                        • StinkieS Offline
                          Stinkie
                          Not too shabby. Maybe lower the exposure a tad - the images look unnaturally bright. At least to me. As for the white spots ... caustics? I'm a Vray noob myself, so that's just a wild guess.
                          In any case, look for Mado's interior settings on the Vray forum. Load those, and take it from there.
                            batas senja
                            hi...it's not look like first work...youre like profesional...good work 👍
                              ScottPara
                              Nice work. Your render times are probably because of everything is so reflective (shiny), but it could be many thing (computer specs, render settings, etc.). The image is quite bright but that would be somewhat correct with white on almost all surfaces. The spots are due to your lighting subdivisions being set too low. Try turning those up and also make sure under "global settings" that your raytracing secondary bias is set to .001 and not 0. This will also help clear some of that up. Overall nice work it just needs some attention to the lighting.
                              Scott
                              Love the fact that some HATE my avatar.....
